The report below gives back a list of AWS VPCs.
The report will only list assets when the following criteria are met:
  • You have Lansweeper 7.1 or higher.
  • There is AWS VPC data scanned.
tblAssetCustom.Manufacturer,
tblAWSContainer.VpcId,
tblAWSContainer.InstanceTenancy,
tblAWSContainer.Region,
tblAWSContainer.State,
tblAWSContainer.Type,
tblAWSContainer.IsDefault,
tblAssets.Lastseen,
tblAssets.Lasttried
From tblAssets
tblAssets.LocationID
Inner Join tblAWSContainer On tblAWSContainer.AssetID = tblAssets.AssetID
Where tblState.Statename = 'Active'
Order By tblAWSContainer.Region,
tblAssets.AssetName
0 REPLIES 0
