09-28-2022 01:18 AM - last edited 3 weeks ago by Mercedes_O
We have two EATON UPS 1500 RC that is connected to the network. Lansweeper will only recognize one, but not both. It will overwrite the existing UPS with other UPS info instead of creating it as a new asset. MAC
Solved! Go to Solution.
01-06-2023 12:12 PM
Hi, I had the same issue and it's to do with a shared MAC address for the USB port, exclude your MAC with this script that you run against the LS DB using the tool...
INSERT INTO tsysMacBlacklist (Mac, Comment) VALUES ('48:6F:73:74:50:43', 'UPS USB Port')
GO
GO
01-06-2023 12:12 PM
GO
GO
04-20-2023 06:51 AM
Works for me! Thanks a lot!
04-20-2023 03:13 PM
10-06-2022 03:46 PM
I have tried the suggested solution, but still the asset is merging.
10-06-2022 04:04 PM
Hello there!
Please reach out to our support team at support@lansweeper.com so we can have a more in-depth look at this.
09-28-2022 01:46 PM
Hello there!
This sounds like a merging issue.
The following forum post contains some useful pointers: https://community.lansweeper.com/t5/forum/asset-deleted-after-rescan/m-p/62151#M35588
