Fahd
i have a small annoying problem, and i hope somebody help me with it,
as mentioned in subject the problem is in RPC availability,
the assets are scanned successfully but after a while it turned RPC unavailable or fire-walled,
even though the windows firewall is OFF, the antivirus firewall is OFF, the RPC service is running,
and still i have this error when scan or deploy installation package on the assets.
what else i have to turn off or on, or services should i stop or run, to remove this error??
my best regards
CyberCitizen
Honored Sweeper
Have you had a look through this article, it covers most of the common RPC issues.
https://www.lansweeper.com/knowledgebase/the-rpc-server-is-unavailable/
