AlistairFS
I'm trying to add network kit to the scanned assets, and for various reasons I'm attempting to use SNMPv3 to do it. I have configured the additional SNMPv3 credentials and added them to the scanning targets for a small subset of test kit. Other colleagues have configured the kit for SNMP and provided me with the details of the credentials; they've used another tool (Orion) to demonstrate that the credentials are good.
In the test group, I have 6 devices, 2 of which respond as expected, but the other 4 do not. There's nothing in their asset record to suggest any errors, just no data. Connections from Orion had the SNMP context set, but for Lansweeper setting or not setting the context seems to make no difference (setting it does stop one of the 'working' devices from responding, but that's by-the-by).
Using DeviceTester.exe also retrieves nothing, for SNMPv3 it returns:
Scanning SNMP..
But we can test SNMP credentials in Orion, so SNMP is enabled. It's v3 so I guess the wrong community bit is just a part of a generic message.
The version of Lansweeper we're running is 8.1 and the switches are HP Aruba 2920,2930 and 5412.
Has anyone seen anything similar and/or have any ideas of things to try?
AlistairFS
Well, looks like we may have an SNMP configuration issue, as an alternative set of credentials seem to work fine. Pretty much proves that the problem is not at the Lansweeper end.
AlistairFS
