mlsoftware
Hi to all and sorry for my english,
Update from 4.0.0.42 to 4.1.0.16 OK.
I check/configure this server with remote desktop connection and for speed reasons we connect at 256 color.
I open configuration tool and obtain attached error "Out of system resource" every time i move mouse over information box at the left.
Issue does not happen if i connect in high color mode (15 or 16 bit).
I hope to understand if this is a bug.
Thanks to all in advanced.
King regards.
Massimo
7 REPLIES 7
WilliamKotze
I have resolved my problem, the lansweeper service account had login error. All issues has been resolved and lansweeper is working again.
WilliamKotze
Yes, I have upgraded to the new version about a week ago, I will try different resolution. This server is VMWARE 4.1 so I will also check that I have VMWARE Tools installed.
WilliamKotze
I have the same issue, out of system resources. Did anyone find a solution?
Did you test this with the latest update? (4.1.0.21)?
Can you please test this with the latest version (4.1.0.21)
wsbellin71
Yes, I am getting the same error message. It started for no apparent reason. I am very consider. Why you able to reproduce the error and provide a fix?
Cannot reproduce this issue.
Anyone else with the same problem?
