The report below gives back a list of Azure virtual machine assets and their disks.
The report will only list assets when the following criteria are met:
  • You have Lansweeper 7.1 or higher.
  • There is Azure virtual machine data scanned.
  • The asset state is active.
tblAzureVirtualMachine.PowerState,
tblAzureVirtualMachine.OsType As [OS Type],
tblAzureVirtualMachine.Region,
tblAzureVirtualMachine.Tags,
tblAzureResourceGroup.Name As ResourceGroupName,
tblAzureResourceGroup.SubscriptionId,
tblAzureDisk.Name As DiskName,
tblAzureVirtualMachineDataDisk.DiskType,
tblAzureDisk.OsType As DiskOS,
tblAzureDisk.DiskSizeGb,
tblAzureDisk.Region As DiskRegion,
tblAzureDisk.Tags As DiskTags,
tblAzureDisk.TimeCreated,
tblAzureDisk.CreationMethod,
tblAzureDisk.StorageAccountType,
tblAzureDisk.CreationSourceType,
tblAzureDisk.Zones,
tblAzureVirtualMachineDataDisk.Lun,
tblAzureVirtualMachineDataDisk.VhdUri,
tblAzureVirtualMachineDataDisk.ImageUri,
tblAzureVirtualMachineDataDisk.IsWriteAcceleratorEnabled,
tblAzureVirtualMachineDataDisk.IsDiskEncryptionEnabled,
tblAzureVirtualMachineDataDisk.CachingType,
tblAssets.Lastseen,
tblAssets.Lasttried
From tblAssets
Inner Join tblAssetCustom On tblAssetCustom.AssetID = tblAssets.AssetID
Inner Join tblAzureVirtualMachine On tblAzureVirtualMachine.AssetId =
tblAssets.AssetID
Inner Join tblAzureResourceGroup On tblAzureResourceGroup.Id =
tblAzureVirtualMachine.AzureResourceGroupId
Inner Join tblAzureVirtualMachineDataDisk On
tblAzureVirtualMachineDataDisk.AzureVirtualMachineId =
tblAzureVirtualMachine.Id
Inner Join tblAzureDisk On
tblAzureDisk.Id = tblAzureVirtualMachineDataDisk.AzureDiskId
Where tblState.Statename = 'Active'
Order By tblAssets.AssetName,
ResourceGroupName
0 REPLIES 0
