alessandro
we are evaluating the use of your software about vulnerability management.
The goal is to automate the discovery of all installed software on linux and windows systems, also including portable programs(windows) and executable java packages without rpm installation(linux).
On windows systems we have seen it is possible to extend the normal perimeter with:
- scan processes: https://www.lansweeper.com/forum/yaf_postst12851_List-of-processes-per-asset.aspx#post46060
- scan files: https://www.lansweeper.com/knowledgebase/report-based-on-file-information/
Are there any similar scans for linux?
Is there a scan on active processes or ports on linux VMs?
Do you have documentation about it?
Thank you
Ale
0 REPLIES 0
