Yecaceres
Hello, does anyone know how to deploy the lsagent using the power shell command, in our company we have automox and it is based on power shell, and you can specify the ip of the scan server, the port and the cloud relay authentication key.
first of all, Thanks
rom
I think this should work:
this is from the online help as far as server, agent key, etc -  you will want to change that as appropriate:
Type ".\LsAgent-windows.exe --server LAN-001 --port 9524 --agentkey 4c2db649-014a-41f5-a01d-08950d7af --mode unattended" and press Enter.
