Anonymous
Not applicable
I'm also facing this problem, I could never fix it because I have other applications in the same webserver and I can't change the date of the users as in the solution from the link:
http://www.lansweeper.com/forum/yaf_postst1259p2_Release-3-5--DATE-format-problem.aspx
Is there any other way to fix this, that does not affect other applications of the webserver?
Thanks,
Paulo
This is indeed a bug, will be fixed next update.
Anonymous
Not applicable
Hello, can you please give me some input on this? I would like to have it corrected in a future release if you confirm it as a bug. Thanks.
Anonymous
Not applicable
I've tried that with Local System user (SID S-1-5-18) but it didn't worked, I have to change the SQL user too and I can't.
But I've checked the Tigra calendar, and it's strange when they put the right european date in the comments (dd-mm-yyyy) but then the script complains about the wrong date in the format dd/MM/yyyy. So I've changed the script and now I can get all working, can you please check if that's a bug? Please check my working code of calendar_eu.js:
// Tigra Calendar v4.0.2 (12-01-2009) European (dd-mm-yyyy)
// http://www.softcomplex.com/products/tigra_calendar/
// Public Domain Software... You're welcome.
// default settins
var A_TCALDEF = {
'months' : ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'],
'weekdays' : ['Su', 'Mo', 'Tu', 'We', 'Th', 'Fr', 'Sa'],
'yearscroll': true, // show year scroller
'weekstart': 1, // first day of week: 0-Su or 1-Mo
'centyear' : 70, // 2 digit years less than 'centyear' are in 20xx, othewise in 19xx.
'imgpath' : 'images/' // directory with calendar images
// date parsing function
function f_tcalParseDate (s_date) {
var re_date = /^\s*(\d{1,2})\-(\d{1,2})\-(\d{2,4})\s*$/;
if (!re_date.exec(s_date))
return alert ("Invalid date: '" + s_date + "'.\nAccepted format is dd-mm-yyyy.")
var n_day = Number(RegExp.$1),
n_month = Number(RegExp.$2),
n_year = Number(RegExp.$3);
if (n_year < 100)
n_year += (n_year < this.a_tpl.centyear ? 2000 : 1900);
if (n_month < 1 || n_month > 12)
return alert ("Invalid month value: '" + n_month + "'.\nAllowed range is 01-12.");
var d_numdays = new Date(n_year, n_month, 0);
if (n_day > d_numdays.getDate())
return alert("Invalid day of month value: '" + n_day + "'.\nAllowed range for selected month is 01 - " + d_numdays.getDate() + ".");
return new Date (n_year, n_month - 1, n_day);
// date generating function
function f_tcalGenerDate (d_date) {
return (
(d_date.getDate() < 10 ? '0' : '') + d_date.getDate() + "-"
+ (d_date.getMonth() < 9 ? '0' : '') + (d_date.getMonth() + 1) + "-"
+ d_date.getFullYear()
// implementation
function tcal (a_cfg, a_tpl) {
// apply default template if not specified
if (!a_tpl)
a_tpl = A_TCALDEF;
// register in global collections
if (!window.A_TCALS)
window.A_TCALS = [];
if (!window.A_TCALSIDX)
window.A_TCALSIDX = [];
this.s_id = a_cfg.id ? a_cfg.id : A_TCALS.length;
window.A_TCALS[this.s_id] = this;
window.A_TCALSIDX[window.A_TCALSIDX.length] = this;
// assign methods
this.f_show = f_tcalShow;
this.f_hide = f_tcalHide;
this.f_toggle = f_tcalToggle;
this.f_update = f_tcalUpdate;
this.f_relDate = f_tcalRelDate;
this.f_parseDate = f_tcalParseDate;
this.f_generDate = f_tcalGenerDate;
// create calendar icon
this.s_iconId = 'tcalico_' + this.s_id;
this.e_icon = f_getElement(this.s_iconId);
if (!this.e_icon) {
document.write('<img src="' + a_tpl.imgpath + 'cal.png" id="' + this.s_iconId + '" onclick="A_TCALS[\'' + this.s_id + '\'].f_toggle()" class="tcalIcon" alt="Open Calendar" />');
// save received parameters
this.a_cfg = a_cfg;
this.a_tpl = a_tpl;
function f_tcalShow (d_date) {
// find input field
if (!this.a_cfg.controlname)
throw("TC: control name is not specified");
if (this.a_cfg.formname) {
var e_form = document.forms[this.a_cfg.formname];
if (!e_form)
throw("TC: form '" + this.a_cfg.formname + "' can not be found");
this.e_input = e_form.elements[this.a_cfg.controlname];
else
this.e_input = f_getElement(this.a_cfg.controlname);
if (!this.e_input || !this.e_input.tagName || this.e_input.tagName != 'INPUT')
throw("TC: element '" + this.a_cfg.controlname + "' does not exist in "
+ (this.a_cfg.formname ? "form '" + this.a_cfg.controlname + "'" : 'this document'));
// dynamically create HTML elements if needed
this.e_div = f_getElement('tcal');
if (!this.e_div) {
this.e_div = document.createElement("DIV");
this.e_div.id = 'tcal';
document.body.appendChild(this.e_div);
this.e_shade = f_getElement('tcalShade');
if (!this.e_shade) {
this.e_shade = document.createElement("DIV");
this.e_shade.id = 'tcalShade';
document.body.appendChild(this.e_shade);
this.e_iframe = f_getElement('tcalIF')
if (b_ieFix && !this.e_iframe) {
this.e_iframe = document.createElement("IFRAME");
this.e_iframe.style.filter = 'alpha(opacity=0)';
this.e_iframe.id = 'tcalIF';
this.e_iframe.src = this.a_tpl.imgpath + 'pixel.gif';
document.body.appendChild(this.e_iframe);
// hide all calendars
f_tcalHideAll();
// generate HTML and show calendar
if (!this.f_update())
return;
this.e_div.style.visibility = 'visible';
this.e_shade.style.visibility = 'visible';
if (this.e_iframe)
this.e_iframe.style.visibility = 'visible';
// change icon and status
this.e_icon.src = this.a_tpl.imgpath + 'no_cal.png';
this.e_icon.title = 'Close Calendar';
this.b_visible = true;
function f_tcalHide (n_date) {
if (n_date)
this.e_input.value = this.f_generDate(new Date(n_date));
// no action if not visible
if (!this.b_visible)
return;
// hide elements
if (this.e_iframe)
this.e_iframe.style.visibility = 'hidden';
if (this.e_shade)
this.e_shade.style.visibility = 'hidden';
this.e_div.style.visibility = 'hidden';
this.e_icon.src = this.a_tpl.imgpath + 'cal.png';
this.e_icon.title = 'Open Calendar';
this.b_visible = false;
function f_tcalToggle () {
return this.b_visible ? this.f_hide() : this.f_show();
function f_tcalUpdate (d_date) {
var d_today = this.a_cfg.today ? this.f_parseDate(this.a_cfg.today) : f_tcalResetTime(new Date());
var d_selected = this.e_input.value == ''
? (this.a_cfg.selected ? this.f_parseDate(this.a_cfg.selected) : d_today)
: this.f_parseDate(this.e_input.value);
// figure out date to display
if (!d_date)
// selected by default
d_date = d_selected;
else if (typeof(d_date) == 'number')
// get from number
d_date = f_tcalResetTime(new Date(d_date));
else if (typeof(d_date) == 'string')
// parse from string
this.f_parseDate(d_date);
if (!d_date) return false;
// first date to display
var d_firstday = new Date(d_date);
d_firstday.setDate(1);
d_firstday.setDate(1 - (7 + d_firstday.getDay() - this.a_tpl.weekstart) % 7);
var a_class, s_html = '<table class="ctrl"><tbody><tr>'
+ (this.a_tpl.yearscroll ? '<td' + this.f_relDate(d_date, -1, 'y') + ' title="Previous Year"><img src="' + this.a_tpl.imgpath + 'prev_year.gif" /></td>' : '')
+ '<td' + this.f_relDate(d_date, -1) + ' title="Previous Month"><img src="' + this.a_tpl.imgpath + 'prev_mon.gif" /></td><th>'
+ this.a_tpl.months[d_date.getMonth()] + ' ' + d_date.getFullYear()
+ '</th><td' + this.f_relDate(d_date, 1) + ' title="Next Month"><img src="' + this.a_tpl.imgpath + 'next_mon.gif" /></td>'
+ (this.a_tpl.yearscroll ? '<td' + this.f_relDate(d_date, 1, 'y') + ' title="Next Year"><img src="' + this.a_tpl.imgpath + 'next_year.gif" /></td></td>' : '')
+ '</tr></tbody></table><table><tbody><tr class="wd">';
// print weekdays titles
for (var i = 0; i < 7; i++)
s_html += '<th>' + this.a_tpl.weekdays[(this.a_tpl.weekstart + i) % 7] + '</th>';
s_html += '</tr>' ;
// print calendar table
var n_date, n_month, d_current = new Date(d_firstday);
while (d_current.getMonth() == d_date.getMonth() ||
d_current.getMonth() == d_firstday.getMonth()) {
// print row heder
s_html +='<tr>';
for (var n_wday = 0; n_wday < 7; n_wday++) {
a_class = [];
n_date = d_current.getDate();
n_month = d_current.getMonth();
// other month
if (d_current.getMonth() != d_date.getMonth())
a_class[a_class.length] = 'othermonth';
// weekend
if (d_current.getDay() == 0 || d_current.getDay() == 6)
a_class[a_class.length] = 'weekend';
// today
if (d_current.valueOf() == d_today.valueOf())
a_class[a_class.length] = 'today';
// selected
if (d_current.valueOf() == d_selected.valueOf())
a_class[a_class.length] = 'selected';
s_html += '<td onclick="A_TCALS[\'' + this.s_id + '\'].f_hide(' + d_current.valueOf() + ')"' + (a_class.length ? ' class="' + a_class.join(' ') + '">' : '>') + n_date + '</td>'
d_current.setDate(++n_date);
while (d_current.getDate() != n_date && d_current.getMonth() == n_month) {
d_current.setHours(d_current.getHours + 1);
d_current = f_tcalResetTime(d_current);
// print row footer
s_html +='</tr>';
s_html +='</tbody></table>';
// update HTML, positions and sizes
this.e_div.innerHTML = s_html;
var n_width = this.e_div.offsetWidth;
var n_height = this.e_div.offsetHeight;
var n_top = f_getPosition (this.e_icon, 'Top') + this.e_icon.offsetHeight;
var n_left = f_getPosition (this.e_icon, 'Left') - n_width + this.e_icon.offsetWidth;
if (n_left < 0) n_left = 0;
this.e_div.style.left = n_left + 'px';
this.e_div.style.top = n_top + 'px';
this.e_shade.style.width = (n_width + 😎 + 'px';
this.e_shade.style.left = (n_left - 1) + 'px';
this.e_shade.style.top = (n_top - 1) + 'px';
this.e_shade.innerHTML = b_ieFix
? '<table><tbody><tr><td rowspan="2" colspan="2" width="6"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td><td width="7" height="7" style="filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src=\'' + this.a_tpl.imgpath + 'shade_tr.png\', sizingMethod=\'scale\');"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td></tr><tr><td height="' + (n_height - 7) + '" style="filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src=\'' + this.a_tpl.imgpath + 'shade_mr.png\', sizingMethod=\'scale\');"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td></tr><tr><td width="7" style="filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src=\'' + this.a_tpl.imgpath + 'shade_bl.png\', sizingMethod=\'scale\');"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td><td style="filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src=\'' + this.a_tpl.imgpath + 'shade_bm.png\', sizingMethod=\'scale\');" height="7" align="left"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td><td style="filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src=\'' + this.a_tpl.imgpath + 'shade_br.png\', sizingMethod=\'scale\');"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td></tr><tbody></table>'
: '<table><tbody><tr><td rowspan="2" width="6"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td><td rowspan="2"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td><td width="7" height="7"><img src="' + this.a_tpl.imgpath + 'shade_tr.png"></td></tr><tr><td background="' + this.a_tpl.imgpath + 'shade_mr.png" height="' + (n_height - 7) + '"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td></tr><tr><td><img src="' + this.a_tpl.imgpath + 'shade_bl.png"></td><td background="' + this.a_tpl.imgpath + 'shade_bm.png" height="7" align="left"><img src="' + this.a_tpl.imgpath + 'pixel.gif"></td><td><img src="' + this.a_tpl.imgpath + 'shade_br.png"></td></tr><tbody></table>';
if (this.e_iframe) {
this.e_iframe.style.left = n_left + 'px';
this.e_iframe.style.top = n_top + 'px';
this.e_iframe.style.width = (n_width + 6) + 'px';
this.e_iframe.style.height = (n_height + 6) +'px';
return true;
function f_getPosition (e_elemRef, s_coord) {
var n_pos = 0, n_offset,
e_elem = e_elemRef;
while (e_elem) {
n_offset = e_elem["offset" + s_coord];
n_pos += n_offset;
e_elem = e_elem.offsetParent;
// margin correction in some browsers
if (b_ieMac)
n_pos += parseInt(document.body[s_coord.toLowerCase() + 'Margin']);
else if (b_safari)
n_pos -= n_offset;
e_elem = e_elemRef;
while (e_elem != document.body) {
n_offset = e_elem["scroll" + s_coord];
if (n_offset && e_elem.style.overflow == 'scroll')
n_pos -= n_offset;
e_elem = e_elem.parentNode;
return n_pos;
function f_tcalRelDate (d_date, d_diff, s_units) {
var s_units = (s_units == 'y' ? 'FullYear' : 'Month');
var d_result = new Date(d_date);
d_result['set' + s_units](d_date['get' + s_units]() + d_diff);
if (d_result.getDate() != d_date.getDate())
d_result.setDate(0);
return ' onclick="A_TCALS[\'' + this.s_id + '\'].f_update(' + d_result.valueOf() + ')"';
function f_tcalHideAll () {
for (var i = 0; i < window.A_TCALSIDX.length; i++)
window.A_TCALSIDX.f_hide();
function f_tcalResetTime (d_date) {
d_date.setHours(0);
d_date.setMinutes(0);
d_date.setSeconds(0);
d_date.setMilliseconds(0);
return d_date;
f_getElement = document.all ?
function (s_id) { return document.all[s_id] } :
function (s_id) { return document.getElementById(s_id) };
if (document.addEventListener)
window.addEventListener('scroll', f_tcalHideAll, false);
if (window.attachEvent)
window.attachEvent('onscroll', f_tcalHideAll);
// global variables
var s_userAgent = navigator.userAgent.toLowerCase(),
re_webkit = /WebKit\/(\d+)/i;
var b_mac = s_userAgent.indexOf('mac') != -1,
b_ie5 = s_userAgent.indexOf('msie 5') != -1,
b_ie6 = s_userAgent.indexOf('msie 6') != -1 && s_userAgent.indexOf('opera') == -1;
var b_ieFix = b_ie5 || b_ie6,
b_ieMac = b_mac && b_ie5,
b_safari = b_mac && re_webkit.exec(s_userAgent) && Number(RegExp.$1) < 500;
I think the logic of "it-extrainfo.aspx" may not be right too, I had to change it, but I'm not quite sure if it's the right way.
<%if lcase(session("dateformat")) = "dd/mm/yyyy" then%><script language="JavaScript" src="scripts/calendar_eu.js"></script><%else%><script language="JavaScript" src="scripts/calendar_us.js"></script><%end if%>
I've changed it to:
<%if lcase(session("dateformat")) = "dd/mm/yyyy" then%><script language="JavaScript" src="scripts/calendar_us.js"></script><%else%><script language="JavaScript" src="scripts/calendar_eu.js"></script><%end if%>
You could run the application pool from a different user.
