kcxstrange
I work in IT and have my call board on my far left monitor not directly in front of me. When I connect to a user's computer I remote in using Lansweeper on my main monitor. The remote session window appears on that far left call board monitor though. Very annoying as I have to drag it back to the main monitor every time. Is there a way to make the remote session window pop up on my main monitor every time instead of the left one? Thanks for any help!
CyberCitizen
Honored Sweeper
Are you using LSRemote? I believe that went end of life and is no longer recommended for use. There is no active development on that, recommendation was to move to another remote control agent.
https://www.lansweeper.com/updates/end-of-support-for-lsremote/
