commandline_be
Hello People, looking for some clarity if not help here.
Using 'deployment' with SSH and Linux scripting is not in the documentation, there is even explicit mention on a page i found that the deployment only works with Microsoft platform products.
Knowing how easy it is to ssh and script on Linux, i assume it may be possible ?
Can this be explained and/or verified ?
Wirkss
You can call powershell in a command prompt from Installer Package using :
powershell -Command "Put your powershell command here"
info
As someone who was REALLY hoping I can use the package deployment options on Linux, I can confirm that everything I read on LANSWEEPER shows it has to be windows based only.
You can find the DEPLOYMENT REQUIREMENTS HERE.
EDIT: I was motivated and tried to pass "commands" (in lansweeper) via command prompt. The theory was to pass
1: c: ssh user@computer
2: $computer# (lansweeper command1)
3: $computer# (lansweeper command2)
But SSH wasn't availble from command prompt and calling powershell from a command prompt didn't work so the entire theory is a bust. I wish they would add it, but it sounds like yet ANOTHER tool we will have to manage to do what lansweeper already does for windows. ugh.
