Justin_Toronto
Is there a way to kill a deployment once you submit it?
CyberCitizen
Honored Sweeper
Not from Lansweeper, you need to kill the remote deployment executable running on the target machine, as well as the setup file / installer. Also delete the task from Task Scheduler.
I have a command on the asset pages that runs a remote command prompt on the end user machine, so I can use the taskkill command fairly quickly to kill it. The task scheduler step takes a little longer.
