‎09-30-2022 02:49 PM - last edited 4 weeks ago by Mercedes_O
Hello
I just completed uploading an office layout and placed my assets in the correct location - unless I'm missing it, where exactly can I see that map w/ assets on it without having to run a report (which only gives data, no map w/ assets) ?
I am using an on-prem installation of LS, v 10.2.4.0.
Under Assets, I only see the option to add a new asset or location - thanks in advance !
** Update - found what I was looking for, simply searched for the location name and the map came up **
Solved! Go to Solution.
‎10-03-2022 02:03 PM
Hello there!
We are glad to hear you were able to retrieve your location map, more information can be found in this KB article as well: https://www.lansweeper.com/knowledgebase/placing-assets-on-a-map/
With the new UI layout, it does become less obvious, but you can find your locations under "asset types" in the "Assets" dropdown menu, as shown below.
Hello there!
