uoeauboenat
I have linux assets who communicate directly and successfully to my server through LSAgent.
All seems good, except they don't validate the SSL certificate that is served on port 9524 of my backend server.
For security reason, I want the communication to fails if the target certificate is not signed by a trusted root/intermediate CA, has expired, or doesn't have the right domain name as subject or SAN.
How do I activate this?
Here is my LsAgent.ini
[default]
Server=myservername
Port=9524
AgentKey=
Enabled=1
AssetId=f5f3ed0e-2bae-11ee-be56-0242ac120002
ComputerName=mycomputername
LastScan=638259698731973036
LastSent=638259698752379614
Status=Running
Version=10.4.2.1
Thank you!
Obi_1_Cinobi
Hello there!
Please reach out to technical support to see whether this is currently possible or not: https://www.lansweeper.com/contact-support/
Thank you for you reply! I will then contact the technical support.
