Mister_Nobody
Honored Sweeper II
We need to track change Windows 10 builds. So I check OS history and write query:
Select Top 1000000 *
From tblOperatingsystemHist
 Then update some Windows 10 but query result is empty.
Please fix tracker to support Win 10 Builds.
Hendrik_VE
Absolutely right,  but difficult to report on though.  Maybe someone with supersqlpowers can right us a query that lines up all past OS upgrades from the last 30 days? Preferably showing old build vs new build.
Hendrik_VE
We've been looking too for some kind of report that shows 'real' OS upgrades. This might show what you're looking for (though I'm not 100% convinced ðŸ˜… 😞
Select Top 1000 tblAssets.AssetName,
a.*
From tblOperatingsystemHist As a
Inner Join tblAssets On tblAssets.AssetID = a.AssetID
Where a.Caption <> (Select Top 1 b.Caption From tblOperatingsystemHist As b
Where a.AssetID = b.AssetID And a.Trackercode > b.Trackercode Order By
b.Trackercode Desc) And a.Lastchanged > GetDate() - 30
Order By tblAssets.AssetName
If tblOperatingsystemHist is empty then you query is useless
rom
Don't laugh, but usually OS in-place upgrades can be caught by the sheer number of KB removals at a single time in the change history.
