‎09-17-2018 10:01 PM
‎09-27-2018 09:52 PM
‎09-27-2018 10:37 PM
crashff wrote:
How would I know if I have a ticket number if I havent seen any emails?
‎09-26-2018 06:15 PM
‎09-27-2018 01:41 PM
crashff wrote:
Hopefully support has received the information and has looked into it. I've noticed the last 3 times I've sent emails to Lansweeper support, I have not received any communication in return.
‎09-20-2018 12:55 PM
‎09-18-2018 06:06 PM
‎09-18-2018 05:07 PM
‎09-18-2018 05:34 PM
KevinA-REJIS wrote:
I'm having a similar problem with some Geist PDUs. If I set up OIDs for the individual Assets, they work perfectly. But if I set up OIDs for the Asset Type/Manufacturer/Model, they don't appear for any of the matching Assets.
‎09-19-2018 07:01 PM
Charles.X wrote:
FYI, if you leave Manufacturer/Model fields empty, the OIDs will be scanned for all assets specified as target. If you fill in one or both of these fields, OIDs will only be scanned for the specified manufacturer/model within the target. Keep in mind that, if you fill in the fields, what you submit must match what is listed as manufacturer/model on the device's asset page. This can either be the scanned manufacturer/model or what was manually overwritten. What you see listed on the asset page is the "correct" value to submit in the OID scanning configuration. If the manufacturer/model submitted in your OID configuration does not match what is listed on the asset page, no data will be scanned
If you've double checked that the Target is correct, and the scan still does not work, it's best to contact our support team with screenshots of your OID scanning target and the asset you are trying to scan.
Edited: correction of the OID scanning information
