Is there a simple way to normalise data per machine if on VPN ?
Accepted Solution
Is there a simple way to normalise data per machine if on VPN? My asset keeps changing the IP?
Accepted Solutions (1)
Riley
Solution
We have a feature called rename detection that can be found under configuration/server options. By default, it is enabled; however, we have added a new setting to this feature that will only check on the model and serial number and not the MAC address; this could help alleviate the duplicate issue you are experiencing.
Windows rename detection - Lansweeper Community
If you cannot collect the correct details from agentless scanning, then a good recommendation would be to use the LsAgent. This way, you capture information daily without the challenge of trying to capture it when clients are on the VPN.
Introduction to LsAgent - Lansweeper Community
Answers (0)
Ask a Question
