12-08-2023 03:14 PM - edited 12-08-2023 10:22 PM
After creating your site and installing Lansweeper, one of the crucial decisions to make is whether to use credential-less or credential-based scanning to discover your IT environment effectively.
Lansweeper employs Credential-free Device Recognition (CDR), a passive scanning to scan your devices without requiring login credentials. This method creates a unique "fingerprint" for each device, consisting of a MAC address and enriched with data gathered from protocols such as DHCP, HTTP, or ARP. Even without credentials, CDR can identify essential information about your devices, including IP address, manufacturer, model, and operating system.
For a more in-depth understanding of how CDR works, check out Credential-free Device Recognition.
CDR is only one element of Lansweeper's passive scanning feature. Explore Passive Scanning to understand the principles behind it and discover how CDR plays a role in this process. |
While CDR is a valuable method for scanning your network, it only scratches the surface when it comes to gathering asset information. With the right credentials in place, you can access a wealth of detailed information about your devices, including hardware and software specifics, security vulnerabilities, and more.
To set up credentials for your scans, navigate to Scanning > Credential vault. In this section, you'll find both default and your own credentials.
Depending on your specific [scan targets], you will create different credentials to match your requirements.
Lansweeper takes the security of your credentials seriously and ensures the safety of your sensitive information through the following measures:
Try NowExperience Lansweeper with your own data. Sign up now for a 14-day free trial.
