simonduz
How hard would it be to add the McAfee Virus info to this?
This is one piece that I would really really like to see. Is it something I could add myself so I don't have to run a seperate WMI script to collect this info?
The reason I was asking is this is listed as one of the options for scanning.. "8. Registry Keys you specify "
Thanks..
simonduz
Haven't tried it yet... I was just wondering. I am going to try it this weekend and will reply as to whether they work or not.
Thanks..
Like the post said, I've experimented with the registry keys in the post to get the settings for the automatic updates.
Could you tell me which registry keys aren't working?
simonduz
Found this post:
http://forum.lansweeper.com/Default.aspx?g=posts&t=27
Looks like what I was looking to do. Now can you tell me if you had ever tested this and did it work for you?
Will it scan any registry key, and how many registry keys can I use in this table... Is there a limit to how many it can scan?
Thanks again.
