sniffer
dear,
I installed 3.5.2.16 lansweeper, I can scan the windows xp product keys, but can't scan the office product keys. The configration of product keys is default. can someone help me?
6 REPLIES 6
sniffer
Problem is resolved. It's my fault. In client the location of registry is different with default. After I modified the location of registry in server, it can display the office product key.
Could you post a screenshot from the registry on the client please.
sniffer
see my attached images. the server is 64 bit windows, and the client is 32 bit windows.
Could you post an extract of your registry please?
Is this on a 64 bit windows?
sniffer
My product keys list is same as the http://www.lansweeper.com/kb/licensekeys.aspx. I installed office 2003 pro and standard version on client PC. but I can't scan any office product key only can find windows xp product key. Also I search the registry for"DigitalProductID" and find the keys locate is correct.
Here is a list of additional keys:
If the key is not on the list it's best to search the registry for "DigitalProductID" to get the correct location.
