quintinh
We run dual monitors around here. Is there any way to make screengrab.exe grab from both or specify which monitor I want a screenshot from?
13 REPLIES 13
cstern
Related question: Does the app support more than 2 monitors? I have a machine which has two video cards and four (4) monitors attached.
cstern
Well, I've just downloaded and tried the beta version (4.0.0.55) and it appears so have resolved the issue. (As well as the other I was having of being able to grab from Win7 machines.)
http://www.lansweeper.com/forum/yaf_postst3222_29-March-Remote-screenshot-40-beta.aspx
UPDATE: Some, but not all machines return a blank image (white) when the target screen is locked. Is this expected behavior?
Yes
cstern
Lansweeper wrote:
Yes
This issue appears to have been resolved with the beta screengrab app then.
cstern
Hmmm... actually... it seems to be when the screens are not the same size or are set at different resolutions.
cstern
Thanks for the speedy reply! All of them are in "extended" (not spanning, duplicate, or other screen only).
Is the OS/videocard on all these machines the same?
cstern
Mix of 32-bit XP Pro and 64-Bit Windows7 Pro. Various video cards.
How exactly is the monitor setup, we'll try to reproduce.
(duplicate/extend/other screen only)?
If it's extended you should get both, otherwise there is only one screen to display.
