AdmirH
I have inserted the code as described in the kb for authentication, minus the compilation debug, since it is already in the code.
After logging in either with a domain username (which I had authenticated as in domain\group or username) or as a local user on the lansweeper server it gives me the following error msg:
System.Data.SqlClient.SqlException: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
I checked on the SQL server and verified that it allows remote connections using both tcp/ip and name pipes.
Any help would be appreciated. I just want to secure my data from domain users, so if there is a simpler way, let me know.
thanks.
Could you post your complete web.config file please.
