Options
‎03-05-2019 01:19 PM
The report below gives back a list of AWS Instances and their volumes.
The report will only list volumes when the following criteria are met:
- You have Lansweeper 7.1 or higher.
- There is AWS Instance data scanned.
- The asset has the active state.
tblAssets.IPAddress,
tsysIPLocations.IPLocation,
tblAssetCustom.Manufacturer,
tblAWSInstance.InstanceId,
tblAWSInstance.InstanceType,
tblAWSInstance.Platform,
tblAWSInstance.Region,
tblAWSInstance.State,
tblAWSVolume.VolumeId,
tblAWSVolume.VolumeType,
Case tblAWSVolume.VolumeType
When 'gp2' Then 'General Purpose SSD'
When 'io1' Then 'Provisioned IOPS SSD'
When 'st1' Then 'Throughput Optimized HDD'
When 'sc1' Then 'Cold HDD'
When 'standard' Then 'Magnetic Volume'
End As VolumeTypeDesc,
tblAWSVolume.Size [Size(GB)],
tblAWSVolume.Encrypted,
tblAWSVolume.Iops,
tblAWSVolume.AttachTime
From tblAssets
tblAssets.LocationID
Inner Join tblAWSInstance On tblAWSInstance.AssetId = tblAssets.AssetID
Inner Join tblAWSVolume On tblAWSVolume.AWSInstanceId =
tblAWSInstance.AWSInstanceId
Where tblState.Statename = 'Active'
Order By tblAWSInstance.Region,
tblAssets.IPNumeric,
Labels:
Built-In Reports
Report Center
0 REPLIES 0
