coec
Hey there, I am looking to have this report only return OS types "Win 2012 R2, Win 2016, Win 2019", and to color code any machine which has a uptime greater than 45 days. I have very little experience working with the custom reports in LanSweeper so was just wondering if someone from the community would be kind enough to help out with this. Thanks in advance!
Select Top (1000000) tblAssets.AssetID,
tblAssets.Domain,
tsysAssetTypes.AssetTypename As AssetType,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tsysIPLocations.IPLocation,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
Case
When tsysOS.osname Is Not Null Then tsysOS.osname
When tblLinuxSystem.OSRelease Is Not Null Then tblLinuxSystem.OSRelease
When tblMacOSInfo.SystemVersion Is Not Null Then tblMacOSInfo.SystemVersion
When tsysAssetTypes.AssetType = -1 And Coalesce(tblSccmAsset.OsCaption,
tblSccmAsset.OperatingSystemNameandVersion, '') <> '' Then
tblSccmAsset.OperatingSystemNameandVersion)
Else ''
End As OS,
tblAssets.SP,
tblAssets.Firstseen As [Created at],
tblAssets.Lastseen As [Last successful scan],
tblAssets.Lasttried As [Last scan attempt],
Convert(nvarchar(10),Ceiling(Floor(Convert(integer,tblAssets.Uptime) / 3600 /
24))) + ' days ' +
Convert(nvarchar(10),Ceiling(Floor(Convert(integer,tblAssets.Uptime) / 3600 %
24))) + ' hours ' +
Convert(nvarchar(10),Ceiling(Floor(Convert(integer,tblAssets.Uptime) % 3600 /
60))) + ' minutes' As UptimeSinceLastReboot
From tblAssets
Left Outer Join tsysOS On tsysOS.OScode = tblAssets.OScode
tblAssets.LocationID
Left Outer Join tblLinuxSystem On tblAssets.AssetID = tblLinuxSystem.AssetID
Left Outer Join tblMacOSInfo On tblAssets.AssetID = tblMacOSInfo.AssetID
Left Outer Join tblSccmAsset On tblAssets.AssetID = tblSccmAsset.AssetId
Where tblState.Statename = 'Active' And tblAssets.Uptime Is Not Null
Order By tblAssets.Uptime Desc,
tblAssets.IPNumeric,
tblAssets.Domain,
tblAssets.AssetName
0 REPLIES 0
