naim
Hello
I get error after deploying software (Couldn't start the remote registry service.)
I deployed 7zip with an msi file and silent mode (/q)
What can be the problem?
If I run it via BAT file it is installed well
The share is ok
Only if it is running via lansweeper i get the error
I run it by domain admin
Eli
Issue caused by a bug which was fixed in the latest Lansweeper release. Don't forget to update your installations.
Please send information on the problem to support@lansweeper.com. We will follow up via email.
