That unfortunately didn't work for me (code below). Also of note - I looked for examples of case utilization and found a report that works fine. The working sample report has it's case statement located within the from statements.
Here's my modified code where I moved the case statement above the from statement. This unfortunately still does not work - it returns <Error while saving: "There was an error parsing the query. [ Token line number = 1,Token line offset = 319,Token in error = scanhistory ]">
Select Top 1000000 tblScanHistory.ScanServer,
tsysScanningMethods.ScanningMethod,
tblAssets.IPAddress,
tblAssets.Domain,
tblAssets.Username,
tblAssets.Description,
tblScanHistory.ScanTime,
tblAssets.Lastseen,
tblAssets.AssetID,
tblScanHistory.Description As Description1,
case when tbl.scanhistory.scantime = tblassets.lastseen then 'success' else 'fail'
End As [scanresluts]
From tblAssets
Left Join tsysAssetTypes On tsysAssetTypes.AssetType = tblAssets.Assettype
Right Join tblScanHistory On tblAssets.AssetID = tblScanHistory.AssetId
Inner Join tsysScanningMethods On tsysScanningMethods.ScanningMethodId =
tblScanHistory.ScanningMethodId
Where tsysAssetTypes.AssetTypename Like 'Windows'
Order By tblScanHistory.ScanTime Desc
This below is *not* my code - it is an example report which uses the case statement and works, and the case statement is located within the "from" statement. I was basing my original code upon how this worked, but of course, my version did not work at all:
Lansweeper report with case in it:
Select Top 1000000 tsysIPLocations.IPLocation,
tAssettype.[asset type],
Count(tblAssets.AssetID) As number
From tblAssets
Inner Join (Select tblAssets.AssetID,
Case When tblAssets.Assettype = -1 Then Case
When tblComputersystem.Domainrole > 1 Then 'Server' Else Case
When Coalesce(tblPortableBattery.AssetID, 0) <> 0 Then 'Laptop'
Else 'Desktop' End End Else tsysAssetTypes.AssetTypename
End As [asset type]
From tblAssets
Left Join tblComputersystem On tblComputersystem.AssetID = tblAssets.AssetID
Left Join tblPortableBattery On tblPortableBattery.AssetID =
tblAssets.AssetID) tAssettype On tAssettype.AssetID = tblAssets.AssetID
Left Join tsysIPLocations
On tblAssets.IPNumeric Between tsysIPLocations.StartIP And
tsysIPLocations.EndIP
Group By tsysIPLocations.IPLocation,
Order By tsysIPLocations.IPLocation,
