AudreyR
Ensuring installation requirements and minimums are met is fundamental to creating a successful Lansweeper trial experience. Your results can be limited without proper installation requirements, leading to various issues.
Installation requirements
To ensure your installations meet the necessary standards, it's crucial to understand and implement the following key requirements:
1.Open ports
Open ports allow communication between different components of your IT system. For a complete list of required ports, check out Ports scanned or used by Lansweeper.
2.Local admin privileges
Local admin privileges are necessary for system management. Depending on your environment, this may include domain, local, or LAPS accounts.
3.Internet access
Internet access is required for system functionalities, such as accessing your site and scanning. Ensure your sync server can access the URLs listed in Internet access requirements.
Meeting recommended minimum specifications is essential to avoid pitfalls and ensure system performance.
Single Server (Scanner, Web, SQL)
  • CPU: 4 cores
  • RAM: 12GB
  • Database (DB) Storage: Approximately 1MB per asset
  • Operating System (OS) Storage: At least 80GB
SQL Server
  • CPU: 4 cores
  • RAM: 8GB
  • DB Storage: Approximately 1MB per asset
Scan Server
  • CPU: 4 cores
  • RAM: 4GB
  • OS Storage: 80GB
After ensuring that all installation requirements and minimum specifications are met, you can continue this training and create a site and install a scanner.
‎12-08-2023 10:18 PM
