lapsteel
This morning I install IIS on the server that is running Lansweeper. I was able to see the web interface. Started to troubleshoot the pc that lansweeper did not have access. Then for a reason that I dont know I have this message when I return to the web console.
Could not load file or assembly 'AjaxControlToolkit' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)
The C drive on wich is install the application have 64.9 GB free and only 3.96 GB are use.
Also I cannot log on to GUI console. It come's back with the error
SQL server does not existe or access denied.
Using visual studio I am able to connect to the database and query allcomputer views.
What is going on.
lapsteel
ok I am back on track.
Reinstall and run ok
