Mully
Is is possible to use a barcode scanner to alter the state of a machine?
We are trying to improve our stock controll processes and it would be helpful if the state of a machine could go from Active to Inactive once scanned.
There is no built-in functionality for automating this. You could manually run the script below under Configuration/Scanning Setup/Database Scripts to set all assets with a barcode to non-active. Copy and paste the code and hit the Execute SQL Code button.
We recommend performing a database backup before executing any scripts.
Update tblassetcustom set state = 2 where barcode <> ''
