fen12
The error, 'Fatal error 9001, contact your system administrator. ' appears when I was updating the report. And I was prompted 'connection failure' when i click on other tabs. What could be the cause? I checked and there is connection to the database server.
Kindly advise. Thank you.
As far as I can find:
This error is reported by the SQL server because there is a problem with the log file.
See : http://support.sas.com/kb/34/668.html
