nivek911
I've got through a lot of the old postings, but I wanted to make sure I understood. Currently, the only thing that triggers the scan is the running of the lsclient.exe correct?
I have remote users that I'd like to poll based on their PC name when they stumble on the VPN. Is there a way I can put their PCs in the queue and check to see if they are present every so often? Since they don't really log onto the domain while connected to the VPN, I can't add the lsclient program to the login script.
Thanks.. V3 looks awesome btw.
You can copy the lsclient to their pc and use a scheduled job on the clients (run each xx minutes)
Scheduled scanning will be in version 3.0
