Options
‎10-29-2007 07:22 PM
Hi all, i'm having an authentication problem (I think). I've checked both web.config and LSservice.exe.config files and seem to be with the right settings.
When I open http://localhost/lansweeper, I get a page similar to the next one: http://img398.imageshack.us/img398/7166/lansweeperac4.jpg
The content of the error messages is the following:
System.Data.SqlClient.SqlException: Error de inicio de sesión del usuario 'lsuser'.
at System.Data.SqlClient.SqlInternalConnectionTds.CompleteLogin(Boolean enlistOK)
at System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject)
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
Can someone help me, please? Thanks.
Labels:
Options
‎10-30-2007 12:28 PM
Thanks for the response. The problem is solved. I couldn't connect because the 'lsuser' was created as "windows user". So I created it as "standard user" in SQL Server.
Thanks again!!!
Thanks again!!!
Options
‎10-30-2007 09:48 AM
Make sure that your SQL server is configured for sql authentication.
What version of SQL server are you using?
Could you post your web.config file please.
