cwalker
I have installed Lansweeper onto my server using the documentation provided. The web console comes up and everything on the server seems to be ok but when I try to run the lsclient.exe from the workstations, it comes back failed trying to connect to the to server. I have tried using the IP address and the hostname of the server with no luck. I have also tried running the server app using Administrator and lanscanner as the user to try and eliminate permission problems. I have tried this on three different workstations using Windows 2000, XP SP1 and XP SP2.
All help would be appreciated.
10 REPLIES 10
The documentation mentions that you should open a port on the firewall of your server, did you do this?
(port 9524 TCP)
