‎02-18-2010 12:49 PM
I have set it on OU filtering and want to scan a specific OU initially, but it dont seem to be scanning anything? I have put the Active Diretory path in correctly. Do I need to do anything to trigger the scanning? We have the premium version.
‎03-17-2010 03:51 PM
The fields you need are in table tblcomputers (username/userdomain)
‎03-17-2010 03:37 PM
Any help would be appreciated.
‎03-17-2010 02:36 PM
‎03-17-2010 01:24 PM
‎03-17-2010 12:42 PM
‎03-17-2010 12:24 PM
‎03-02-2010 02:01 PM
The other question I have is, how often does Lansweeper scan softwares on the same PC? or does it need to be triggered manually or can the settings be changed for it to scan software etc every day or so?
‎03-02-2010 02:09 PM
blm wrote:
Thanks for all the help so far from everyone.
You need to change the "waittime" for software with the configuration tool.
‎02-23-2010 05:15 PM
A few hints on how to use web.config settings to secure access to specific files/folders:
http://support.microsoft.com/default.aspx/kb/316871
http://bytes.com/topic/asp-net/answers/759313-whats-easiest-way-secure-web-folder
Using IIS and NTFS permissions, you can remove anonymous access and add a security group with read access to the virtual folder.
