udiburg
How can I configure the program to monitor if TrendMicro antivirus is installed?
Udi.
8 REPLIES 8
Anonymous
Not applicable
It's well documented, sorry I can't help you more than this.
Anonymous
Not applicable
Scan for the file PccNTMon.exe then this report will give you the computers where Trend is not installed:
SELECT     TOP (100) PERCENT dbo.tblComputers.Computername AS Computer, dbo.tblFileVersions.Lastchanged
FROM dbo.tblComputers INNER JOIN
dbo.tblComputersystem ON dbo.tblComputers.Computername = dbo.tblComputersystem.Computername LEFT OUTER JOIN
dbo.tblFileVersions ON dbo.tblComputers.Computername = dbo.tblFileVersions.Computername AND dbo.tblFileVersions.Found = 0
WHERE (dbo.tblFileVersions.FilePathfull LIKE '%PccNTMon.exe') AND (dbo.tblComputersystem.Domainrole LIKE '1')
ORDER BY Computer
This report will exclude servers since I only use Trend on PC's
ORDER BY Computer
Ok,
But how do I create a report from it in the freeware version?
ORDER BY Computer
Thanks,
I will check and reply.
You can do it in the free version as well if you manually edit the sql commands and tables.
udiburg
Wow! Sounds complicated. I have SQL express, can I do it on it as well?
If it's in the software list you can create a report for it.
If it's not in the software list you need to specify the filename to scan for and create a report based on this.
udiburg
As I read in the documentation, creating new reports is available only in the Premium version. Isn't it?
