Styze
I have followed the installation document step by step. All running well except the web console.
Please help me.
Some details in french (sorry i'm french) :
29 REPLIES 29
Click the button "configuration" on tab "site web"
Styze
Lansweeper wrote:
check if the extension .aspx maps to "c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_isapi.dll"
How?
Styze
A web.config file is missing.
It's the problem?
How i can replace it?
ejensen
Make sure ASP.Net 2.0 is allowed in the "Web Service Extensions" section in IIS.
XP doesn't has this screen
Could you check "configuration" and check if the extension .aspx maps to "c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_isapi.dll"
1) have you changed anything in the web.config file
2) check if your root site is set to asp.net 2.0
3) if you don't use your root site, rename the web.config
Styze
the html file works.
Could you place a simple test.html file in the folder and see this.
This way we will know if it's asp.net or IIS
Styze
I made it but nothing changed. It's ASP.net problem?
Could you try this:
go to folder : C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727>
run "aspnet_regiis.exe -i"
