marvinwb
Guys,
I have Lansweeper installed and configured in AD enviroment.
The machines are scanned at user logon (via login script), but changes will not be updated on the database.
Example.
After running SP installation on an XP machine, the database will report SP after a whole week of usage.
Any ideas?
Thanks a million
No you need to set all records to 0 in the table
marvinwb
Is there a general setting to get all the items queried every time by just modifying one entry?
You can configure for each item when it refreshes (nr of days)
If you set it to 0 it will refresh every time that the users log on.
marvinwb
Smikkel,
Should it not refresh when users log on? Will that change affect all items in lansweeper (IE, Software installed, patches, etc)?
Thanks in advance
You can configure the "waitdays" in the TsysWaittime table
