bernhard
Hello everybody!
Is it possible to include network printers in lansweeper?
I want to see wich network printers are on the clients installed (and maybe the serialnumber of the printer!?)!
Thanks in advance!
mbonal
Yes you can but you will need to dowload this application, save it to a CSV file and then use Microsoft SQL Import Utility and create a new TABLE. Once the table is created, you create a new view and then insert that new View into one of the reports tables. Then You go to the Lansweeper GUI Console and create a report. Then you have Network printers!
http://www.366software.com/trial.html
