Simmarc
Good morning everyone,
I was wondering if Lansweeper had an option for an "Offline" inventory of sorts. We have a lot of spare equipment that we want to keep track of. I know we could add them manually, but we prune the DB every 15 days for offline equipment.
Is there a simplier solution integrated in the service?
Thanks a bunch! 🙂
Simmarc
Perfect! It even shows up as online if the asset is found on the network.
This product is magic, love it!
Thanks!
When you go to the asset page of an asset and then you click on edit in the menu on the left you will go to the edit page. You will see on this page a check box with the value Never delete by cleanup options. If you check this the asset will not be deleted by the cleanup options.
