harringg
I see that under Advanced Actions, you can Uninstall software.
Is there a tool to allow you to install software from LanSweeper's Actions menu?
I drove over to another building to install our AV software (because Lansweeper alerted me this PC was missing it. Yea!)
Could this have been done using an Action?
bob_11
This might be do to the av provider was displayed wrong with in ls I ran in to this with Eset as ls said it was Eset and the PC said it was Eset corp...
O and for ur second question yes u can install remotely using psexec \\pc msiexec.exe /i "(fullpath)\program.msi" ALLUSERS=1 /q /norestart only use pre made Msi files as they will install funny if you extract the Msi from the exe file......
Hope that helps 🙂
Lansweeper gives you just enough to make anything possible
Lansweeper displays the same software information found under Add/Remove Programs (Programs & Features) on the client machine.
A Remote Install tool is not currently available. This feature is on our customer wish list, but we do not currently have a release date for it.
SyncMasta
did you think about call the Support of the new AV ??
In some cases (related to count of CALs) the AV-Manufactorer is able to program a uninstall programm for your domain
Greeting, Syncmasta
