Pollak
I belive I have configured the tools correct per the Premium Tolls documentation. On the local server where they are installed I gett port 445 not accessilbe which I can fix, but attempting this from the Lansweeper Console on a workstaion I get the following error.
Error: File not found.
This is the command line that is configured on the server.
\\servername\lstools\lsremote.exe servername {computer} {domain}
Please advise,
Niles
Pollak
Okay issue resolved. Adding {domain} to the command line works but I think the straw that broke the camel's back was the security setting that Windows Server 2008 sets on executables. Right click the exe file, properties and "unblock".
Now is there a way to get the lsremote.exe (2.0.0.201 beta) to save the settings under the Remote Server tab?
Thanks,
Niles
Pollak
Could you post a screenshot of the actions configured and a screenshot of your share please.
File not found means that the file lsremote.exe could not be found on that path.
PS.
Your action should more look like : \\servername\lstools\lsremote.exe {computer}
