KRH
I have tried to make customizations to Device Overview list. Moved devices from network devices to switches etc. Problem is that these customizations are lost after some time. What is causing this? LS version is 4.1.0.18
FrankW
After the next scan, the details you changed are overwritten. i had the same problem until i found the "lock against scanning" option (it was there, but i haven't seen it).
You can find the option on the right side next to field you are changing (padlock).
Hope it helps ...
