BenKnox
Question 1.
Purchasing Lansweeper Premium is $149 yearly, i was wondering if the initial $149 is to purchase the software and license, and then the $149 each year after is to continue support?
Or do you have to pay the $149 each year just to use the software?
Question 2.
Regarding the active scanning, is this able to be controlled to scan within a particular OU or IP Address range.
Question 3.
Is there any kind of a trial version for lansweeper premium?
I know there is a shareware version but this lacks the main features that we would be purchasing Lansweeper for such as active scanning and software reporting.
Question 4.
Would it be okay to run the lansweeper service, IIS and SQL server all on the same computer? Or would it get too overworked?
Should take less than a month.
It's already being tested in some companies without any problems.
BenKnox
Thankyou for the reply, sounds promising.
Also I was just wondering if you have a rough time line on how long you will trial the domain and OU active scanning in the beta phase before it actually goes into production.
Thanks 🙂
1) The price is a yearly payment to use the software.
2) Not at the moment, in the next version you will be able to selectively select domains and OU's (beta should be ready by the end of the month)
3) If you are not satisfied we can offer a money back guarantee.
4) Shouldn't be a problem, you can always lower the amount of simultaneous scans if you have problems.
