scsu
Hi!
A report called "No F-Secure installed" helps us to control the numbers of F-Secure installations
It works great with Windows Xp 32bit, but not with Windows 7 64 bit.
Here is the SQL Code
Select Top 1000000 dbo.tblComputers.ComputerUnique, dbo.tblComputers.Computername, dbo.tblComputers.Username, dbo.tblComputers.Domain, dbo.tblOperatingsystem.Description, dbo.tblFileVersions.Lastchanged From dbo.tblComputers Inner Join dbo.tblComputersystem On dbo.tblComputers.Computername = dbo.tblComputersystem.Computername Left Outer Join dbo.tblOperatingsystem On dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername Left Outer Join dbo.tblFileVersions On dbo.tblComputers.Computername = dbo.tblFileVersions.Computername Where dbo.tblFileVersions.FilePathfull Like '%fssm32.exe%' And dbo.tblFileVersions.Found = 0 Order By dbo.tblFileVersions.Lastchanged Desc
What`s wrong?
Greetings
12 REPLIES 12
scsu
Tried it, but there are still 20 machines with wrong results. Mostly of them with a 64bit system.
***EDIT***29.10.2010
Well, i restarted the lansweeper service, now it works!
Thank you!
try this one
dbo.tblComputersystem.SystemType
Where dbo.tblOperatingsystem.Computername Not In (Select
tblfileversions.Computername From tblfileversions
Where tblfileversions.FilePathfull Like '%fssm32.exe%' And
tblfileversions.Found = 1)
scsu
Today it looks like the x86 clients work again. But there are still 20 machines, with a wrong result because of two configured scan-directories.
SQL Query:
Select Top 1000000 dbo.tblComputers.ComputerUnique, dbo.tblComputers.Computername, dbo.tblComputers.Username, dbo.tblComputers.Domain, dbo.tblOperatingsystem.Description, dbo.tblFileVersions.Lastchanged, dbo.tblFileVersions.FilePathfull, dbo.tblComputersystem.SystemType From dbo.tblComputers Inner Join dbo.tblComputersystem On dbo.tblComputers.Computername = dbo.tblComputersystem.Computername Left Outer Join dbo.tblOperatingsystem On dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername Left Outer Join dbo.tblFileVersions On dbo.tblComputers.Computername = dbo.tblFileVersions.Computername Where dbo.tblFileVersions.FilePathfull Like '%fssm32.exe%' And dbo.tblFileVersions.Found = 0 Order By dbo.tblFileVersions.Lastchanged Desc
Can you post your latest sql query please.
scsu
Both are added. But it looks like lansweeper checks both directories for every machine.
When fssm32.exe is not in both directories, it says = no f-secure installed.
You will need to add both in the list of scanned files.
scsu
Alright! But since I`ve added the 64bit path, the report only looks under "c:\Program files (x86)" and not the old path ( "c:\programfiles\" )
Currently "%programfiles(x86)% is not supported, you will need the full path "c:\program files (x86)\"
scsu
I`ve added the 64bit path to the "scanned files". But now, all 32bit Machines say, they have no F-Secure installed (because there is no path like "%programfiles(x86)%
How can I configure the Report, to look in the 32bit path OR in the 64bit path?
