‎08-17-2009 07:10 PM
About 3/4 of the machines on my network are failing to scan, and returning:
Wmierror The RPC server is unavailable 0x800706BA
Wmierror Cannot connect to DCOM port 135 : Firewalled?
No 3rd party firewalls, Windows firewall has port 135 open. Have even tried shutting it off.
We have Symantec Endpoint Protection, only AV installed. This has caused problems with other network applications in the past, so we have tried opening an exception, shutting off SEP, and even uninstalling it. No luck there.
Here are two flavors of typical Error Log entry:
4/29/2009 1:17:29 PM: 211AW0511 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
at LansweeperService.MdlWmi.GetWMI(String Querystr, String Table, LS_Computer& mycomputer, String section, SqlConnection& sqlcon)
5/5/2009 10:00:12 AM: RM138AL0309 Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
at System.Management.ManagementObjectSearcher.Get()
Have tried putting in lsclient and firing off manually; that doesn't seem to help.
Can't seem to find any pattern to the ones that DO scan, and a lot of them are returning the above errors, but show all of their info anyway.
I'm very confused. Any ideas??
Thanks,
Bill Stewart
IT Support, Buist Moore Smythe McGee P.A.
wstewart@buistmoore.com
843-720-4670
‎08-18-2009 10:14 PM
When I disable SEP, it appears to work:
Remote WMI test
Found: Microsoft Windows XP Professional Service Pack 2
Found: Microsoft Windows XP Service Pack 2
And when I re-enable it, it still works . . . huh?
‎08-18-2009 07:33 PM
Even so, it has still blocked some network applications. It's a pain in the butt to set up for Microsoft Active Sync, for example.
‎08-18-2009 07:58 PM
wmjstu wrote:
SEP has a firwalkl available, but we have not installed it.
Could you try disabling the service and try the connectiontester.
‎08-18-2009 07:31 PM
Remote admin mode = enable
Does the "Symantec Endpoint Protection" have a build in firewall? Have you tried disabling it.
‎08-18-2009 05:38 PM
netsh firewall show state shows 135 <null>; when firewall disabled, it shows that.
Had any problems with the Symantec Endpoint Protection?
‎08-18-2009 07:18 AM
1) the computer isn't configured correctly, see http://www.lansweeper.com/kb/accessdenied.aspx (maybe try to repair WMI with point 6)
2) if you are very sure that 1 is correct then it must be a firewall (windows build-in or other)
Did you try a "netsh firewall show state" on this computer?
‎08-18-2009 12:32 AM
Could not open connect to the host on port 135; Connect failed
‎08-18-2009 12:13 AM
without the ":"
‎08-18-2009 12:11 AM
Telnet 10.128.2.66:135
Is this incorrect?
