mtcuser
Is it possible to run lstrigger minimized or have it close when it has completed scanning?
If I have to go through and Trigger Scan a computer manually, having to close the command window adds to the clicks/mouse movements I have to make. If it would close when its done, that would be much more helpful. Thanks for the help.
mtcuser
Thanks for the reply.
When I removed /K from the Action, I was still left with the command window open. Which is not what I was looking for. I then removed cmd.exe /k altogether and now the trigger just runs and closes how I want it to.
you need to remove the "/k" parameter from cmd.exe
