stimpy_555
Hi After running the upgrade procedure for the database, we recieve the following error from the web site. All data seems to have been upgraded fine;
System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.web40getdiskspace'.
Please see the following error file from the upgrade script;
stimpy_555
This resolved the issue.. Thanks
Most likely you are missing some of the latest updates.
I suggest downloading the latest setup.exe and choose to upgrade.
