stiwa
i have a computer where scanning does not work properly and it does not stop:
Aborted ams\amsdblab01\1 scanning takes longer than 2 hours, repair wmi on this machine! 19/04/2013 14:21:56
Aborted ams\amsdblab01\1 scanning takes longer than 2 hours, repair wmi on this machine! 19/04/2013 13:20:55
Aborted ams\amsdblab01\1 scanning takes longer than 2 hours, repair wmi on this machine! 19/04/2013 12:19:55
First, why is scanning not much earlier aborted? I think you can lower the threshold to 10 minutes or so.
Second, how can i stop it?
Using v5069
stiwa
Coworker restarted the computer, that solved the problem.
WMI (Windows Management Instrumentation) is most likely corrupt on the client machine. Could you do the following so we can confirm this:
- Copy the LsPush.exe found in Program Files (x86)\Lansweeper\Client on your Lansweeper server to the problem machine.
- Run the executable on the client machine. The machine will be scanned locally and the scan results attached to email and copied to your temporary folder.
Afterwards, contact support@lansweeper.com and provide us with:
- Link to this forum thread.
- The LsPush file that was generated.
- The Errorlog.txt file present in Program Files (x86)\Lansweeper\Service on your Lansweeper server.
