Options
‎12-03-2009 04:53 PM
We run dual monitors around here. Is there any way to make screengrab.exe grab from both or specify which monitor I want a screenshot from?
Labels:
13 REPLIES 13
Options
‎04-12-2010 08:55 PM
I'm using the latest version of screengrab (2.1.0.8). Most of our workstations have a dual monitor setup. When I attempt to get a screen grab, it does not grab the secondary monitor, instead that space is just blank (white).
Options
‎12-04-2009 09:42 AM
sure, just use the computername as a parameter (like it's done from the action screen)
Options
‎12-03-2009 06:40 PM
That rocks! Thanks.
Follow up question ... I was planning to write a script that will take a screenshot, retrieve the JPG, timestamp it (basically rename) and then archive. While I like the little interface you put on (it's a great little bit of polish for the product), it's gonna get in the way as Lansweeper is installed on my workstation. Is it possible to run this from the command line and not have the dialog display?
Options
‎12-03-2009 05:50 PM
The latest version of screengrab should grab from both monitors at once.
