BSONO
A little background. I had 3.5.1 installed and working great. Then, uninstalled to move lansweeper service and website to another server. That didn't work out, so I tried to install it back on the original server and now getting this error after install. This is with a fresh database created. Thanks in advance for any help.
System.Data.SqlClient.SqlException: Invalid object name 'dbo.Tsysservicestatus'.
System.Data.SqlClient.SqlException: Invalid object name 'tsysconfig'.
BSONO
I got my problem solved. I installed Lansweeper and had it create new database locally. Then, had the SQL DBA moved the database. Uninstalled/Reinstalled Lansweeper and pointed it to the database on the remote server and it worked.
The installer creates a database called "lansweeperdb" and it configures the config files to point to this database.
Normally the sql dba shouldn't create any databases.
You can check lansweeperservice.exe.config and web.config to see if there are pointing to the correct database.
Tsysservicestatus and tsysconfig didn't exist in version 3.2 so I'm guessing you are connecting to an old database.
Anonymous
Not applicable
If you connect to the right database, it should work fine, it looks like you're not connecting to the right database, or some objects are missing.
Anonymous
Not applicable
On the download page did you use the "Lansweeper 3.5.1 installer" file?
http://www.lansweeper.com/Download.aspx
BSONO
I did. Just to be sure, I downloaded it again and had the SQL DBA create a brand new database. Installed and got the same problem. Could there be something lingering from the old install?
